https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Generating a differential input in SPICE https://designers-guide.org/forum/YaBB.pl?num=1112922308 Message started by alfredo_p on Apr 7th, 2005, 6:05pm |
Title: Generating a differential input in SPICE Post by alfredo_p on Apr 7th, 2005, 6:05pm ;D Hi, Pardon my ignorance, but does anyone know how to generate a differential input signal to stimulate a differential amplifier and analyze its AC behavior in a SPICE simulation? I've tried to apply a single-ended V AC input passed through an ideal transformer to generate two signals that are opposite in phase. I am seeing decent amplification levels with this approach but I am uncertain about whether the inductance of the transformer would influence the frequency response of the amp. Thank you very much! |
Title: Re: Generating a differential input in SPICE Post by Ken Kundert on Apr 7th, 2005, 7:24pm See http://www.designers-guide.org/Analysis/diff.pdf. -Ken |
Title: Re: Generating a differential input in SPICE Post by alfredo_p on Apr 7th, 2005, 10:32pm Thank you very much! :) |
