https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> question on RF pad design https://designers-guide.org/forum/YaBB.pl?num=1115152238 Message started by analogic on May 3rd, 2005, 1:30pm |
Title: question on RF pad design Post by analogic on May 3rd, 2005, 1:30pm i m trying to design some pads (analog input, analog output) for GHz operation. the parasitics introduced by ESD diode and pad metal, pin, bonding wire make the distortion unacceptable. Can any one tell me how they handle the problem in commercial chips? Thanks. |
Title: Re: question on RF pad design Post by Sid on May 24th, 2005, 7:50pm I do not have too much RF experience, but I can take a guess at some potential ways to reduce your pad/package parasitics. 1. Try to use "deep-trench isolation" under your pads if available in your process. 2. Do not use ESD devices on the analog pads and handle wafer testing in a controlled environment if possible - however it is best if you use at least some minimal ESD protection. 3. Avoid using bond-wires (i.e. no packaging) and use high-frequency RF probes for testing - these probes are typically gnd-signal-gnd probes for high-performance. Else you may want to use flip-chip packaging. -Sid |
