Design >> RF Design >> noise of VCO
https://designers-guide.org/forum/YaBB.pl?num=1115403651
Message started by pppp on May 6th, 2005, 11:20am
Title: noise of VCO
Post by pppp on May 6th, 2005, 11:20am
I am running pnoise on a VCO. Could some one tell me the result is in single-side or double-side means?
Thanks a lot.
Title: Re: noise of VCO
Post by pancho_hideboo on May 8th, 2005, 8:28am
It is SSB-Phase Noise.
Although you can extend a sweep frequency from negative to positive like following, the result is SSB-phase noise
pnoise  (  Vout  0  )  pnoise  sweeptype=relative  relharmnum=1
+       start=-100  stop=100  step=5  maxsideband=15  iprobe=V0
+       refsideband=1  noisetype=sources  annotate=status  save=allpub
+       saveallsidebands=yes
Post by pppp on May 9th, 2005, 12:09pm
Thank you very very much. It seems I gained 3dB here since negtive sideband noise is already folded.
