https://designers-guide.org/forum/YaBB.pl Simulators >> AMS Simulators >> problem with ideal switches in Cadence https://designers-guide.org/forum/YaBB.pl?num=1120481901 Message started by vivkr on Jul 4th, 2005, 5:58am |
Title: problem with ideal switches in Cadence Post by vivkr on Jul 4th, 2005, 5:58am Hi, I wonder if anyone has experienced a similar problem using the special "sp1tswitch" provided with Spectre. This switch is useful if you want to configure a netlist differently for different analysis and very useful. However, if I have any such switch in my netlist (even one completely isolated from any net), Spectre refuses to perform a noise analysis citing a singular matrix as the source of error. Any suggestions will be welcome. Thanks Vivek |
Title: Re: problem with ideal switches in Cadence Post by Ken Kundert on Jul 5th, 2005, 3:47pm It appears to be a bug. You should report it to Cadence. -Ken |
Title: Re: problem with ideal switches in Cadence Post by jbdavid on Oct 2nd, 2005, 6:25pm that element is OK.. but I found Verilog A to be much more flexible.. for an example, there is a listing for a loop-opener in the paper below which includes an (outdated) example of its use. "Functional Verification of a Differential Operation Amplifier" ... a fully differential current mirror opamp with n-channel input devices ... support the development of a verification script. Figure 1 Fully Differential Current Mirror Opamp with CMFB The following table ... http://www.cadence.com/whitepapers/FVofDiffOpAmp_wp.pdf - 309.8KB Outdated because today one would use the STABILITY analysis to look at loop gain and phase margin.. JBD |
Title: Re: problem with ideal switches in Cadence Post by Ken Kundert on Oct 2nd, 2005, 10:55pm It just occurs to me that if you have a switch isolated in a circuit, then it will result in a singular matrix unless both ends of the switch must have DC paths to ground. -Ken |
Title: Re: problem with ideal switches in Cadence Post by jbdavid on Oct 3rd, 2005, 11:28pm sounds like bmslib sw_no would be a good alternative in that case.. jbd |
