https://designers-guide.org/forum/YaBB.pl Modeling >> Behavioral Models >> frequency difference detector https://designers-guide.org/forum/YaBB.pl?num=1121519554 Message started by svensl on Jul 16th, 2005, 6:12am |
Title: frequency difference detector Post by svensl on Jul 16th, 2005, 6:12am I would like to build a frequency difference detector, using digital components only. It should be able to compare the signal frequency to a reference frequency and detect which frequency is faster. It should then output the difference of the two frequencies. The signals will go in to a charge pump with a LP filter to obtain the average value. Furthermore, it should be able to do the comparison within 1 period and also prevent slipping, meaning there should be almost no limitations on how much the reference and signal frequency can be apart for the circuit to work. Can anyone suggest a circuit, name or paper that might address above issues? Thanks Svensl |
Title: Re: frequency difference detector Post by svensl on Jul 19th, 2005, 5:54am I had a look at "Digital Logic Implementation of the Quadricorrelators for Frequency Detector" by Yoon and Lee and implemented it in VerilogA. While the scheme does work I was wondering whether there are other circuits that might permorm better. For example, the resolution of the frequency difference could be a bit better. Could someone suggest another circuit that does frequency difference detection? Cheers, sven |
Title: Re: frequency difference detector Post by jbdavid on Oct 2nd, 2005, 6:03pm This is a circuits question.. not a modeling question.. jbd |
Title: Re: frequency difference detector Post by Paul on Oct 9th, 2005, 2:13pm Sven, many phase detectors can perform (within some limits) frequency detection too. It depends whether the fact their output is proportionnal to the phase error is problematic in your case or not. I would suggest you have a look at the collection of papers in "Monolithic Phase Locked Loops and Clock Recovery Circuit", Editor B.Razavi. Paul |
