https://designers-guide.org/forum/YaBB.pl Other CAD Tools >> Entry Tools >> Re: Printing Schematic https://designers-guide.org/forum/YaBB.pl?num=1123849067 Message started by Andrew Beckett on Aug 14th, 2005, 12:15am |
Title: Re: Printing Schematic Post by Andrew Beckett on Aug 14th, 2005, 12:15am This is really a case of RTFM. You need to have set up the .cdsplotinit file - see the plotting configuration guide: <instdir>/doc/plot/plot.pdf (also easily located in "cdsdoc"). Then use Design->Plot->Submit (I think that's the menu, from memory). It's not that hard to set up! Regards, Andrew. |
