https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> how to overwrite a file in Veriloga? https://designers-guide.org/forum/YaBB.pl?num=1125594213 Message started by tumeda on Sep 1st, 2005, 10:03am |
Title: how to overwrite a file in Veriloga? Post by tumeda on Sep 1st, 2005, 10:03am Who can tell me how to overwrite a file in Veriloga? I use these commands " $fopen(fp) & $fstrobe(fp, ...) & $fclose(fp)" to write the output periods of a PLL into a file. If I do a simulation again, the output results are just added into the previous results. How can I firstly delete the old simulation results, then wirte new simualtion results into the file. :'( Thanks a lot!!! |
Title: Re: how to overwrite a file in Veriloga? Post by Geoffrey_Coram on Sep 1st, 2005, 11:23am The $fopen system function defined in 1364-1995 (from which Verilog-AMS is defined) did not have an argument for opening in read/write/append text/binary. Curiously, the LRM does not say whether $fopen was supposed to append or truncate. (Probably some simulators do one thing, and others do another.) The extra argument was added in 1364-2001, so you may find that your simulator does, in fact, support the argument. (Vendors had to implement it for digital Verilog, so why not allow the functionality in V-AMS?) $fopen("filename", "w") |
Title: Re: how to overwrite a file in Veriloga? Post by tumeda on Sep 2nd, 2005, 1:58am Geoffrey_Coram, thank very much! you are right. The following is found in CDSDOC file. fopen_function ::= multi_channel_descriptor = $fopen ( "file_name" [ "io_mode"] ) ; ..... io_mode is one of three possible values: w, a, or r. The w or write mode deletes the contents of any existing files before writing to them. The a or append mode appends the next output to the existing contents of the specified file. In both cases, if the specified file does not exist, $fopen creates that file. The r mode opens a file for reading. An error is reported if the file does not exist. I added the option in the code, but the simulation results is always appended to the old results? What's a problem? ??? |
Title: Re: how to overwrite a file in Veriloga? Post by Geoffrey_Coram on Sep 2nd, 2005, 4:37am If the simulator behavior doesn't match the documentation, then you should file a bug report with the vendor. Do the results get appended even if you completely restart? Ie, Spectre allows you to put multiple analyses in a single netlist and maybe it appends everything from the same netlist, but if you run the whole netlist again, do the results still get appended? Do you have any @(initial_step) code around your $fopen? There was some ambiguity in the LRM as to what initial_step meant for DC, and some simulators re-use a single DC op-point to compute multiple AC analyses, so maybe initial_step isn't happening. |
Title: Re: how to overwrite a file in Veriloga? Post by tumeda on Sep 2nd, 2005, 5:09am Thanks a lot for Geoffrey_Coram' help! I made a mistake in my veriloga Model. :P I used "if $realtime==25e-6, $fclose(fp)" to close the file, but actually the file is not closed. Hence the simulation results are always appended into the file. Now I corret the syntax to "if $realtime>=25e-6, $fclose(fp)". It works now in order. :D I have great fun to discuss problems at hier! |
Title: Re: how to overwrite a file in Veriloga? Post by Geoffrey_Coram on Sep 2nd, 2005, 7:56am I'm guessing that you don' t need the mode argument "w" -- that this is the default, and that your original problem was just that you weren't properly closing the file. Am I right? |
Title: Re: how to overwrite a file in Veriloga? Post by tumeda on Sep 2nd, 2005, 10:05am yes, u are right! |
