https://designers-guide.org/forum/YaBB.pl Modeling >> Behavioral Models >> How to Generate & view 1/f noise using spectre https://designers-guide.org/forum/YaBB.pl?num=1126940868 Message started by sphere83 on Sep 17th, 2005, 12:07am |
Title: How to Generate & view 1/f noise using spectre Post by sphere83 on Sep 17th, 2005, 12:07am Hi guys, I'm new to analog circuit design and I wish to know how to generate and view the 1/f noise spectrum of a simple nMOS transistor using Cadence spectre. Please help & thanks in advance. Kindest regards, Sphere :) |
Title: Re: How to Generate & view 1/f noise using spe Post by Andrew Beckett on Sep 19th, 2005, 8:42pm I'm not entirely sure what you're asking here (it's a bit vague). In order to see 1/f noise, you need to have the appropriate parameters in your device models - exactly what those parameters are depends on the model type. Traditionally these were called af, ef, kf - but newer models have different parameters which can be used instead. Apart from that it's a matter of doing a noise or sp analysis (or pnoise/psp, qpnoise/qpsp for periodic or quasi-periodic circuits) and looking at the results. Reading the manuals would probably help (Spectre user guide/reference guide and analog simulation help in cdsdoc). Regards, Andrew. |
Title: Re: How to Generate & view 1/f noise using spe Post by Andrew Beckett on Sep 19th, 2005, 8:43pm Also, since you posted this in the behavioural models section, perhaps you're asking how to do this in a behavioural model language? If so, you can use the flicker_noise() function in Verilog-A. But I suspect you just posted the question in the wrong place? Regards, Andrew. |
