https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> question on ldo voltage regulator https://designers-guide.org/forum/YaBB.pl?num=1127303222 Message started by navin_kumar on Sep 21st, 2005, 4:47am |
Title: question on ldo voltage regulator Post by navin_kumar on Sep 21st, 2005, 4:47am IN LINEAR CMOS LDO VOLTAGE REGULATORS --STUDY SAYS THAT PMOS HAVE STABILITY PROBLEMS COMPARED TO THE NMOS PASS ELEMENT CLARIFY THE STABILITY POINT FOR ME --WHETER BECAUSE NMOS WILL BE SOURCE FOLLOWER CONFIGURATION SO IT IS HAVING LOW OUTPUT IIMPEDENCE |
Title: Re: question on ldo voltage regulator Post by ywguo on Sep 21st, 2005, 9:07pm Hello, Navin, Yes. You are right. Yawei |
Title: Re: question on ldo voltage regulator Post by navin_kumar on Sep 21st, 2005, 11:07pm Hi Yawei thanks for clarifying the doubt could u please give any good paper link for nmos pass element low drop out voltage regulator design navin |
Title: Re: question on ldo voltage regulator Post by ic_engr on Sep 22nd, 2005, 8:39am Hello Navin, There is a good paper in 2005 ISCAS Titled: "A Low DropOut CMOS Regulator with High PSR Over Wdieband Frequencies" by V. Gupta |
Title: Re: question on ldo voltage regulator Post by ywguo on Sep 25th, 2005, 1:48am Hi, Navin, You can get Gupta's paper and many good references on the following link. http://users.ece.gatech.edu/rincon-mora/publicat/pubs.htm Best regards, Yawei |
