https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> Error message from divider model without HiddenSta https://designers-guide.org/forum/YaBB.pl?num=1128094710 Message started by tumeda on Sep 30th, 2005, 8:38am |
Title: Error message from divider model without HiddenSta Post by tumeda on Sep 30th, 2005, 8:38am Dear Ken Kundert I reallly appreciate your answer for my previous questions. Now I tried to directly use the behavioral model codes of divider without hidden state. Unfortunately, there is an error message. ### Error found by spectre during SpectreHDL compile. …... line 40: Error: (Archaic Syntax) Does not comply with the Accellera Verilog-AMS 2.0 Standard and beyond. To comply with the current standard, delete the null statement. Null statements (also known as empty statements and coded as just `;') can be used only in case or event control statements. ### After then, I deleted the semicolon ( ; ) in the line 40 and tried again. But there is still new error message: ### Error found by spectre during SpectreHDL compile. …… line 41: Error: analog operator `ddt' embedded in conditionally executed statement or expression. ### Now, I am confused about that, what's wrong? My icfb version is 5.1.0 02/01/2005. The following are only some lines of your codes. Code:
Title: Re: Error message from divider model without Hidde Post by Andrew Beckett on Oct 2nd, 2005, 12:38am A whole bunch of extra checks were put into the verilog-a parser around the time of the version you're using - but some of these were reporting things that aren't really problems. These were fixed around March 2005 - so in IC5141 and MMSIM60 versions of spectre after that, the messages are no longer given. I just tried the models from the hidden state paper in IC5141 USR2 and MMSIM60 ISR 10, and the warning is not given. So use a later subversion, and the problem should go away. Regards, Andrew. |
