https://designers-guide.org/forum/YaBB.pl Other CAD Tools >> Entry Tools >> Assura LVS passes incorrect https://designers-guide.org/forum/YaBB.pl?num=1129007792 Message started by asdf on Oct 10th, 2005, 10:16pm |
Title: Assura LVS passes incorrect Post by asdf on Oct 10th, 2005, 10:16pm Whan running Assura second time for the same cell it sometimes shows correct results whan really there are errors. I use Assura with the Virtuoso LE. Why this is the case and how the problem can be solved? Thanks! |
Title: Re: Assura LVS passes incorrect Post by Andrew Beckett on Oct 12th, 2005, 1:41pm No idea. You should contact Cadence customer support via whatever is your normal support channel, because this doesn't sound right... Regards, Andrew. |
