https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Sampled noise simulation w/ Spectre https://designers-guide.org/forum/YaBB.pl?num=1129085752 Message started by chiu on Oct 11th, 2005, 7:55pm |
Title: Sampled noise simulation w/ Spectre Post by chiu on Oct 11th, 2005, 7:55pm The PNOISE analysis in Spectre gives strange results of sampled thermal noise from a simple resistor-capacitor network. After SINC compensation, the noise PSD is flat, but the integrated noise from 0 to fs/2 varies depending on the resistance R instead of 64uV/1pF fixed. Why is this? Thanks, - Yun Chiu 10/11/05 |
Title: Re: Sampled noise simulation w/ Spectre Post by Frank Wiedmann on Oct 11th, 2005, 11:33pm Did you set the maxsideband parameter large enough? Please see section 2.2 of http://www.designers-guide.org/Analysis/sc-filters.pdf for details. |
Title: Re: Sampled noise simulation w/ Spectre Post by chiu on Oct 12th, 2005, 3:51pm Thanks for your suggestion. I used a 1k resistor and a 1pF capacitor, sampled at 10MHz. The following is my PSS and PNOISE statement: pss_x pss period=T tstab=0 maxacfreq=1000*fclk swp_x sweep param=nres values=[100 1k 10k] { pns_x (vo vss) pnoise start=0 stop=0.5*fclk lin=1e2 maxsideband=1000 \ noisetype=timedomain noisetimepoints=[0] numberofpoints=1 } I got a total sampled noise 177, 56, and 18uV for the resistance 100, 1k, 10k ohm, respectively. Any suggestions? |
