https://designers-guide.org/forum/YaBB.pl Design >> High-Power Design >> Help on layout for power transistor https://designers-guide.org/forum/YaBB.pl?num=1129873417 Message started by ywguo on Oct 20th, 2005, 10:43pm |
Title: Help on layout for power transistor Post by ywguo on Oct 20th, 2005, 10:43pm Hi, I am designing a LDO with about 20mA output current. Would you please introduce any books or tutorials on the layout for power transistor? Thanks Yawei |
Title: Re: Help on layout for power transistor Post by sheldon on Oct 21st, 2005, 8:29am Yawei, Hastings book, listed in the books of the Designers guide, section, includes discussion of power transistor layout. The second edition is now available. Best Regards, Sheldon |
Title: Re: Help on layout for power transistor Post by loose-electron on Aug 3rd, 2006, 4:28pm MOS or Bipolar? The MOS devices are straightforward, just be very fussy about minimizing all your metal and contac resistance paths. A bipolar one is a lot more picky, bipolar power transistors require ballast in the form of emitter resistance to make sure the currents all balance across the Vbe junctons of the parallel devices. Otherwise one junction runs hot, and all the current goes through there until that junction fries. (Warning - Not seen in simulation!) On the LDO, be careful with the feedback stability, and the ESR of the compensation network. Jerry |
Title: Re: Help on layout for power transistor Post by richard88 on Aug 24th, 2006, 10:15pm Sheldon, I've the first edition. Could you provide the important difference between the two editions ? I also like the first edition. Thanks, Richard sheldon wrote on Oct 21st, 2005, 8:29am:
