https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> Substrate noise coupling https://designers-guide.org/forum/YaBB.pl?num=1130683295 Message started by ssk_288 on Oct 30th, 2005, 6:41am |
Title: Substrate noise coupling Post by ssk_288 on Oct 30th, 2005, 6:41am Hi, I am trying to model the effect of the substrate noise on the LNA. If assume that VCO has a peak to peak swing of 1.2 volts then what will be a good estimate of sinusoidal noise in the substrate due to the VCO. Is there any heuristic formulas to estimate the noise in the substrate. Thanx SUDHIR |
