https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> Analog bus limitation, any work-around ? https://designers-guide.org/forum/YaBB.pl?num=1131166523 Message started by ekne on Nov 4th, 2005, 8:55pm |
Title: Analog bus limitation, any work-around ? Post by ekne on Nov 4th, 2005, 8:55pm Hi Using AMS Designer and want to do: electrical amx; real V_amx_3; real V_amx_2; initial begin #50; V_amx_3 = V(amx[3]); V_amx_2 = V(amx[2]); etc..... but get an ncelab error that this is not supported i.e. analog bus in "digital domain". So is there a way to work-around this ? Not, talking about changing the schematic to not use an analog bus i.e. define two separate signals. Why isn't this supported, don't really see why it should be a limitation at all. (spice/digital busbit notations < vs [ ? perhaps ? but that shouldn't be a limitation) Thanks //BEE ??? |
Title: Re: Analog bus limitation, any work-around ? Post by jbdavid on Nov 9th, 2005, 9:26am I wrote up a great idea, thats NOT the answer to your problem.. Yes workaround is easy.. don't do the conversion in the logic domain.. do it in the analog block.. |
Title: Re: Analog bus limitation, any work-around ? Post by jbdavid on Nov 9th, 2005, 9:31am ie: electrical amx; real V_amx_3; real V_amx_2; analog begin @(timer(50n)) begin // this is a ONE time event, like initial block // initial begin // #50; V_amx_3 = V(amx[3]); V_amx_2 = V(amx[2]); etc..... |
Title: Re: Analog bus limitation, any work-around ? Post by Andrew Beckett on Nov 15th, 2005, 11:12am Hi BEE, There's a PCR for this - 295207. It's an implementation limitation at the moment - I've asked for a status update on this PCR. Regards, Andrew. |
Title: Re: Analog bus limitation, any work-around ? Post by ekne on Nov 15th, 2005, 7:31pm Thanks Mr Andrew I thought I give this forum a try. Very interesting one. Will keep on returning to it. ::) Thanks again. //BEE |
