https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> The methods to avoid the negative delay time https://designers-guide.org/forum/YaBB.pl?num=1132220433 Message started by tumeda on Nov 17th, 2005, 1:40am |
Title: The methods to avoid the negative delay time Post by tumeda on Nov 17th, 2005, 1:40am Hello, I would like to discuss about delay time in the modeling of CP. (Listing 10 in paper jitter+phase noise) " ... parameter real td= 200e-12; parameter real jitter=20e-12; ... dt=jitter*$dist_normal(seed,0,1); ... I(out)<+transition(Iout*state, td+dt,tt) ... " The vaule of the delay time, i.e. td+dt, should avoid negative. There are two metods to aovid that. Method 1 : Set the "td" enough large, e.g. 500e-12 or even larger. I would like to confirm my question: Does the delay time not influence the jitter calculation for the PLL. Because I though the delay times are same for all transition edges. Is it right??? Method 2 : Set the delay time td= 3*jitter, and cut other values, if the td+dt is negative. Actually, the distribution is not true gaussian distribution, but the influence for jitter calculation is very small. "... if td+dt<0 td+dt=0; end I(out)<+transition(Iout*state, td+dt,tt) " Which method is better from your side? Any anser would be appreciate!!! |
