https://designers-guide.org/forum/YaBB.pl Design Languages >> VHDL-AMS >> how to compile Verilog in vhdl-ams with opt.- ms https://designers-guide.org/forum/YaBB.pl?num=1132652201 Message started by saubook on Nov 22nd, 2005, 1:36am |
Title: how to compile Verilog in vhdl-ams with opt.- ms Post by saubook on Nov 22nd, 2005, 1:36am Hi all, Could you help me, I have a problem following: I utilise the simulator ADVance MS v3.0_1.1 to simulate all circuits in Vhdl-ams. It's ok. Now I want to integrate a module written in Verilog in the program (code) of Vhld-ams, so I have to compile the module in Verilog before. When compiling this Verilog module, the command is: valog source/Verilog/res.va -ms (compile file res.va – very simple resistor - with the option “-ms” – obligation). But I encounte the error as following: # Compiling file source/Verilog/res.va # Model Technology ModelSim SE vlog 5.7d Compiler 2003.05 May 11 2003 # ** Error: (vlog-25) Invalid ModelSim library "/tima3/dang/VHDL-AMS/work". No _info file found. # No such file or directory. (errno = ENOENT) # ** Error: /tima3/dang/VHDL-AMS/source/Verilog/res.va(1): Cannot open `include file "constants.h" # ** Error: /tima3/dang/VHDL-AMS/source/Verilog/res.va(2): Cannot open `include file "disciplines.h" # -- Compiling module res # ** Error: /tima3/dang/VHDL-AMS/source/Verilog/res.va(7): near ",": expecting: '(' # ** Error: /tima3/dang/VHDL-AMS/source/Verilog/res.va(8): near "exclude": expecting: ',' ';' # ** Error: /tima3/dang/VHDL-AMS/source/Verilog/res.va(11): near "<": expecting: ',' ';' # ** Error: /tima3/dang/VHDL-AMS/source/Verilog/res.va(11): near "/": expecting: ',' ';' Could you tell me what to do, how to correct these errors? If I use the command: valog source/Verilog/res.va (without option -ms) there is no error, but I cannot call (instantiate) this Verilog module in the vhdl-ams program (par ex. in the file testbench). Thanks you very much. PS: code of res.va `include "constants.h" `include "disciplines.h" module res(p, n); inout p, n; electrical p, n; parameter real r=1 exclude 0; analog begin I(p,n) <+ V(p,n)/r; end endmodule |
Title: Re: how to compile Verilog in vhdl-ams with opt.- Post by Paul on Nov 22nd, 2005, 12:30pm Hi, AFAIK, valog requires two arguments, the source file and the target library, as inputs. The error message states that it could not find the target library. The other error messages are probably not significant and due to this primary issue. BTW, I'm not sure you are required to use the -ms option. This option tells the simulator to use the stand-alone Modelsim kernel for the respective module, instead of the digital part of the single-kernel mixed simulator. At least for VHDL it is not required. Paul |
