https://designers-guide.org/forum/YaBB.pl Simulators >> AMS Simulators >> Parameter sweeping in Verilog AMS https://designers-guide.org/forum/YaBB.pl?num=1138689482 Message started by Rob on Jan 30th, 2006, 10:47pm |
Title: Parameter sweeping in Verilog AMS Post by Rob on Jan 30th, 2006, 10:47pm Hi I have a question about running a parametric sweep with the verilog ams simulator in Cadence. I am modeling hardware impairments in a receiver chain up to and including some digital processing. I have defined several global dynamic parameters from within the Cadence AMS Environment, and I am hoping to automate several consecutive simulations from command line in which I vary some of these parameters. I am wondering if this can be done, and if not, if there is another way to do this without using global parameters. Thanks a lot, Rob |
