https://designers-guide.org/forum/YaBB.pl Simulators >> AMS Simulators >> spectre segmentation fault https://designers-guide.org/forum/YaBB.pl?num=1140939319 Message started by svensl on Feb 25th, 2006, 11:35pm |
Title: spectre segmentation fault Post by svensl on Feb 25th, 2006, 11:35pm I recently upgraded cadence and since the update I keep running into simulation problems with spectre when simulating VerilogA files. The spectre version in use is 5.1.0 10/24/2005. The problem is the following: When changing already existing verilogA code that I had run previously Spectre gives me a segmentation fault. I noticed that when I delete the created compilation directory filename.va.ahdlcmi and re-run it then it works fine. This did not used to be like this. Before the update I could change the VerilogA code and never run into a segmentation fault. Any ideas why that is? BTW, I am using RedHat EL4. Regards, Sven |
Title: Re: spectre segmentation fault Post by Andrew Beckett on Feb 26th, 2006, 7:53am Hi Sven, One of my colleagues filed a PCR on this. I don't recall when it was fixed (or even if it was fixed). I'll look it up when I'm back in the office, and post what I find here. Regards, Andrew. |
Title: Re: spectre segmentation fault Post by Andrew Beckett on Feb 26th, 2006, 9:22am The PCR is: PCR: 850785 Title: bus error when modify veriloga code and rerun simulation The problem was partly fixed in IC5141 USR3, but that's the version you're using. I think you need to do a Simulation->Stop before modifying the Verilog-A code - and then it should be OK. The bug still hasn't been fixed - we need to trigger a stop and restart of spectre to cure this. Regards, Andrew. |
Title: Re: spectre segmentation fault Post by svensl on Feb 27th, 2006, 2:18am Thanks for your response Andrew. Good to know that it is a bug and not due to something I do wrong. Regards, Sven |
Title: Re: spectre segmentation fault Post by babya on Aug 10th, 2006, 6:41am yee, i also used to get this darn error frequently. it used to pop up after some three four simulations if done one after another. what i usually do is copy that same code to another cell view. then it'll start running properly. |
