https://designers-guide.org/forum/YaBB.pl Other CAD Tools >> Entry Tools >> Problems to start LVS in assura3.1.4 https://designers-guide.org/forum/YaBB.pl?num=1141220191 Message started by cyrus on Mar 1st, 2006, 5:36am |
Title: Problems to start LVS in assura3.1.4 Post by cyrus on Mar 1st, 2006, 5:36am Hello together, I have the following problem during the LVS check. When I start the LVS I get the following the message that the LVS failed. The problem is described as follows: Segementation violation Did someone has this problem ? Is this a bug? Because with assura 3.1.2 the LVS runs. Greetz |
Title: Re: Problems to start LVS in assura3.1.4 Post by Paul on Mar 1st, 2006, 12:50pm Cyrus, you mentioned Assura 3.1.2, but what version are you currently using? What Cadence version are you using, what is your OS (type and release)? Did you check Sourcelink for possible solved problems? Paul |
Title: Re: Problems to start LVS in assura3.1.4 Post by cyrus on Mar 2nd, 2006, 8:58am As mentioned in the top line I used assura 3.1.4 that did not run! The software is installed on a solaris workstation SunOS 5.8. Cadence version is 5.1.41 |
