https://designers-guide.org/forum/YaBB.pl Modeling >> Behavioral Models >> SST Analysis https://designers-guide.org/forum/YaBB.pl?num=1142982817 Message started by ASTRIX on Mar 21st, 2006, 3:13pm |
Title: SST Analysis Post by ASTRIX on Mar 21st, 2006, 3:13pm AA I am modelling an rf reciever, when modelling the noise I faced a proplem which is that when modelling mixer's noise an SST analysis should be used, But when modelling the LPF, which contains Laplace transform, there is some conflict between the SSt and the 'LTF, and the output is strange. I wonder if there is a solution for this problem. Yours Shady Ragab |
Title: Re: SST Analysis Post by Eugene on Mar 22nd, 2006, 10:45am What does SST stand for? What does LTF stand for? |
