https://designers-guide.org/forum/YaBB.pl Analog Verification >> Analog Performance Verification >> sigma delta simulation question https://designers-guide.org/forum/YaBB.pl?num=1143013397 Message started by chungmnig on Mar 21st, 2006, 11:43pm |
Title: sigma delta simulation question Post by chungmnig on Mar 21st, 2006, 11:43pm Hi ~~~ I am a Taiwan student ,study in taipei university of technology. I research in SC sigma delta ADC. I have some problem in simulation that. First i use spectre transient to simulated then use fft of wavescan to find PSD. But the noisefloor is always only -40~-30dB , all blocks are satisfied spec. I try to redesign but the same. Is there has any option in transient analysis i should choose? another question is how long the simulation time is enough ? (if my spec is clock rate 2MHz , input signal is 2KHz) sorry my english is so poor... thank for your help ~~!! |
Title: Re: sigma delta simulation question Post by sheldon on Mar 22nd, 2006, 3:53am Chungming, Please see the following thread, http://www.designers-guide.org/Forum/YaBB.pl?num=1135134048 it includes provides some general guidelines for simulating sigma-delta A/D Converter. It also reference another discussion about setting up ADC simulations. It should be possible to achieve low in-band noise floors with the proper setup, -120dB, and much lower, -150dB, with more effort. One note: please review the A/D Converter setup discussion. The current choice of 2kHz as an input frequency may not produce the expected results. The issues are outlined there. Best Regards, Sheldon |
Title: Re: sigma delta simulation question Post by chungmnig on Mar 22nd, 2006, 4:23am sheldon very thanks for yoir help And you say 2kHz as an input frequency may not produce the expected results. But my design spec is low frequency low noise sigma delta AD (10Hz ~ 5KHz) How should i do in simulation that thanks~~~!! |
Title: Re: sigma delta simulation question Post by sheldon on Mar 22nd, 2006, 5:45am Chungming, An example would be to use an 8192 sample FFT for high accuracy. Assuming that you will use the Hanning window to suppress spectral leakage, you will need to sample the input signal twice or setup for the simulation for 4096 samples. So the simulation time is simulation start-up time + 409.6us. Using window functions such as the Hanning Window tends to "smear" the signal. In the case of the Hanning Window, the signal occupies about 1.5 bins. As a result, it can be difficult to distinguish signal from distortion. Oversampling reduces the bin size and makes the results easy to understand. It also acts to suppress the numerical noise floor. So for a 4096 sample FFT and a 2MHz sample rate, you might want to try to simulate from (11/4096)*2MHz or 5371.09375Hz to (19/4096)*2MHz, 9277.34375Hz, or (23/4096)*2M, 11230. 46875Hz. Other values in the input range are (13/4096)*2M, 6347.65625Hz, and (17/4096)*2M, 8300.78125Hz. BTW, the choice of 4096 is just a best guess. You may might want to experiment with more or less FFT samples depending on the your FFT noise floor requirements. If you are using Spectre, there are some additional optimizations that are possible. Sheldon |
Title: Re: sigma delta simulation question Post by chungmnig on Mar 22nd, 2006, 8:13pm sheldon , i very appriciate your hlep but how long the start-up time i should be take? is it means all circuit work properly? about 1ms is enough? or longer? how long is enough? and if choise input signal is 13/8192*2M or 3173.828125Hz (FFT 8192point) simulation transcient time is start-up 1.26ms (four input signal cycle) + 819.2u = 2.08ms then use wavescan do FFT from 1.26ms to 2.08ms and 8192 point the FFT get input signal is 2.6 cycle.....? is it correct?? and why is 11/4096*2M why not 12 or 14 /4096*2M why must be odd number like 11,13,19,23 ......... thanks a lot ~~ ~!!! |
Title: Re: sigma delta simulation question Post by sheldon on Mar 23rd, 2006, 7:54am Chungming, Estimating start-up time is difficult since it is a function of the circuit design. Ideally, only one sample period is required. However, if you are using capacitive common-mode feedback, the common- mode feedback loop can take time a long time to settle. So please wait until the circuit has reached sinusiodal steady-state before performing the fft. The choices were not odd numbers, for example, 15 was not included. The choices were prime numbers. If the input frequency and the sampling frequency are harmonically related, then only certain frequencies are exercised, that is, all the energy occurs at the harmonic frequencies. For more information about ADC testing, please check the following link. http://www.analog.com/UploadedFiles/Associated_Docs/495568568Section8.pdf Sheldon |
Title: Re: sigma delta simulation question Post by chungmnig on Mar 23rd, 2006, 9:50am sheldon, very thanks your reply and paper i had already readed the paper and some my curious problem in simulstion would be resoled i will try it~~ very thank for your help~~~~ ;) |
Title: Re: sigma delta simulation question Post by Julian18 on Oct 12th, 2009, 8:03pm sheldon wrote on Mar 23rd, 2006, 7:54am:
Hi Sheldon: Just out of curiosity, why do we have to choose prime numbers in selecting the input frequency? I built up a behavior model myself, and just tested several f_in's at different bin locations, i.e. 15, 20,23,36. and do 8192-FFT, the simulation figure is in the attachment, which shows that only the fbin=36 case failed to plot a proper output spectrum. Thanks. |
Title: Re: sigma delta simulation question Post by Berti on Oct 13th, 2009, 6:18am Julian, Sheldon has already given the reason for selecting a prime number for the input frequency: Quote:
However, I think the choice of a prime number is more important for other architectures than the sigma-delta modulator where you want to make sure that you signal exercises all codes. By the way, your 'bad' spectrum seems to be corrupted by spectral leakage. Do you use windowing? Regards |
Title: Re: sigma delta simulation question Post by Julian18 on Oct 13th, 2009, 8:56pm Berti wrote on Oct 13th, 2009, 6:18am:
Hi, Berti: Thanks for the reply. Maybe I am wrong about it, but I believe "Harmonically related" means two frequencies have some common factor. When we are doing FFT, we have to make them "harmonically related", since they are both multiples of bin width. and for the windowing, you are right, I am just blindly using Rect window. But I can get the right(? or plausible) spectrum when a prime fbin is picked in regardless of the the window type, on the other hand, if I am using Hann window, all numbers seem to lead a reasonable spectrum(see the attachment), prime or not. Any comment on this? Best Regards. Julian |
Title: Re: sigma delta simulation question Post by Berti on Oct 13th, 2009, 10:40pm Hi Julian, If you use a rectangular window all you frequencies must to lie on a single bin, otherwise you get noise leakage into neighboring bins. Cheers |
Title: Re: sigma delta simulation question Post by Julian18 on Oct 14th, 2009, 3:16am HI Berti: You are right. I carefully choose the frequency of input to be f_s*bin_location/n_fft. Where bin_location is the desired input frequency location, such as 11, 23, etc. Regards |
Title: Re: sigma delta simulation question Post by ywguo on Oct 14th, 2009, 11:41pm Hi, The key is not prime number, but coprime numbers. For example, a composite number 15 is still good for 4096 point FFT because 15 and 4096 are coprime numbers. Since we always do 2^n point FFT in data converter simulation and testing, odd number is always good choice because odd number and 2^n are always coprime numbers. Hi Julian, fbin = 36 has spectrum leakage because the chaotic behavior of sigma-detla modulator copromise the coherent sampling. The output is not N complete cycles. When doing simulation, this problem often occurs, but not always occurs. It can occur even if the input signal locates in an odd number bin. fbin = 20 and 36 look good for 8192 point FFT because the sigma-delta modulator does not show quantization noise clearly. For eg., fbin = 20 and 8192 point FFT, it equivalents to fbin = 5 and 2048 point FFT. That means all quantization noise concentates on bins numbered multiples of 4. It is very clear if you simulate Nyquist rate data converter. Best Regards, Yawei |
Title: Re: sigma delta simulation question Post by vivkr on Dec 22nd, 2009, 5:55am Hi, Choosing the signal to fall exactly on a bin and making the signal frequency coprime with respect to the sampling frequency are a must when simulating Nyquist converters with coherent sampling, but not necessary for sigma-delta converters because of 2 reasons: 1. The presence of shaped quantization noise anyway mandates the use of windowing, else everything is fudged up due to spectral leakage. So you anyway do not have coherent sampling. 2. The shaped noise again guarantees that the "quantizer" input is sort of dithered or randomized, preventing the quantization noise power from concentrating on the harmonics. That being said, it is still a good idea not to put the signal frequency in an odd bin. Regards, Vivek |
