https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> Verilog A Event https://designers-guide.org/forum/YaBB.pl?num=1143074667 Message started by yaxazaa on Mar 22nd, 2006, 4:44pm |
Title: Verilog A Event Post by yaxazaa on Mar 22nd, 2006, 4:44pm Can someone tell me how to do integration between two events in Verilog-A? Foe example, when signal a passed trigger point, the function starts to do integration, after detected signal b passed trigger point, intergation stop. Thanks. |
Title: Re: Verilog A Event Post by Geoffrey_Coram on Mar 23rd, 2006, 5:49am @(initial_step) integ = 0; @(cross(V(ctrl), +1)) integ = 1; // triggers when V(ctrl) crosses 0 in the positive direction @(cross(V(ctrl)-2,+1)) integ = 0; // triggers when V(ctrl) crosses 2 in the positive direction V(out) <+ idt(integ * V(in), 0); Note that V(ctrl) must start below zero, or else the cross function won't detect a crossing. |
Title: Re: Verilog A Event Post by Marq Kole on Mar 24th, 2006, 2:18am Or use the @(above) event if you want V(ctrl) to be able to start above 0 from the start of your simulation. With @(above) the event is triggered also during (implicit) DC analysis. @(above(V(ctrl))) integ = 1; @(above(V(ctrl))) integ = 0; BTW @(above) is an Verilog-AMS 2.2 feature so may not be available in all simulators yet. Alternatively, test for V(ctrl) during the @(initial_step) @(initial_step) integ = (V(ctrl) > 0) ? ((V(ctrl) > 2) ? 0 : 1) : 0; |
