Modeling >> Passive Devices >> how to model the non-volatile component
https://designers-guide.org/forum/YaBB.pl?num=1145979150
Message started by circuitdesigner on Apr 25th, 2006, 8:32am
Title: how to model the non-volatile component
Post by circuitdesigner on Apr 25th, 2006, 8:32am
how to model the non-volatile component?
I desire model a component which could conserve the information
for example, firstly, the resistance is 10K ohm, after a big current, its resistance change to 15k ohm and this resistance
will always 15k, only a opposite direction big current pass the component the resistance return to 10 k ohm.
thank you very much
