https://designers-guide.org/forum/YaBB.pl Simulators >> AMS Simulators >> NCelab error: unresolved instance https://designers-guide.org/forum/YaBB.pl?num=1147105487 Message started by Cri Azzolini on May 8th, 2006, 9:24am |
Title: NCelab error: unresolved instance Post by Cri Azzolini on May 8th, 2006, 9:24am Hi all! I am trying to simulate a circuit with Cadence AMS-Designer; the DesigPrep phase goes well (neither warning nor errors) but when I launch "Run Simulation" from the AMS-plugin menu of the Cadence Hierarchy Editor, I have got: ncelab: *E,CUCFUN (no HDL source, 0|0): istance 'I15' of the unit <my_cell_A> is uresolved in <my_library.my_cell_B.schematic> The log file ncelab.log consulted by means of the Cadene NCBrowse provide the following explanation: "The specified instance in the named module could not be resolved using the 5.x configuration specification available" Actually I can not fix this error since I do not undestand what the "5.x config specification" is! May anyone help me? Is there a exaustive manual for all the NCelab warnings/errors? I was not able to find it in the CDSdoc hierarchy .... Thanks and bye, Cri |
Title: Re: NCelab error: unresolved instance Post by bernd on May 8th, 2006, 9:44am Try to create an explicit *.vams netlist for your cell <my_library.my_cell_B.schematic>, e.g. with 'CIW->Tools->AMS->Netlist...'. The retry the 'Design Prep...' & 'Run Simulation...' steps. Bernd |
Title: Re: NCelab error: unresolved instance Post by Cri Azzolini on May 8th, 2006, 10:04am Thanks Bernd, it seems to work! Thanks! Now I have to netlist a lot of blocks since the error I posted is repeated for many istances. Thanks again and bye, Cri |
Title: Re: NCelab error: unresolved instance Post by bernd on May 9th, 2006, 12:56am Quote:
This should not be the case, maybe it helps if you put 'my_library' into the Hierarchy Editors Global Bindings Library List and then do a Design Prep again, this is just an assumption. But you can always create a AMS netlist for your schematic if you modify your Check & Save options, CIW->Tools->AMS->Options..., 'Check and Save', enable 'Generate AMS netlist' there. Bernd |
Title: Re: NCelab error: unresolved instance Post by Cri Azzolini on May 9th, 2006, 1:32am Thanks for your time, Bernd: I am happy to find a great expert on this field! On the contrary, I am at the very beginning of mixed-mode simulation. As far as I can see, I found a little but significative difference between the analog flow (Analog Design Environment -> Spectre -> Calculator -> Waveform Window AWD) and the AMS-Designer flow suggested by the Tutorial (Hierarchy Editor -> NCsim -> SimVision for result display): in SimVision, before starting the mixed-mode simulation, I have to choose the signal I am interested to and to add them to the SimVision waveform display. Then the simulation is started and the result are dislayed: it happens to me that if I add a signal (not previously chosen) to the wavform strips, no data are available and the signal is not displayed! This is very frustrating since for large circuits, you cannot always forecast which signal you need to check, especially if the circuit does not work properly and a debug is needed! In your experience, is it possibile to add signal to the SimVision waveform strip once the simulation is finished or are only the previously chosen signal saved? Thanks again and bye, Cri |
Title: Re: NCelab error: unresolved instance Post by bernd on May 9th, 2006, 2:34am Quote:
No not as far as I know. But you can also use AMS out of the Analog Design Environment if you use the most recent Cadence versions/updates of NC-sim (IUS stream) and DFII (IC stream) optional MMSIM stream, but don't ask me for exact version numbers. Can you see 'ams' in your simulator choices in the Analog Design Environment? Quote:
Thanks for the laurels, but I'm just started 2 month ago to set up the AMS stuff for my company. That's why I know most of the traps, because I'm steeped in already. Bernd |
