https://designers-guide.org/forum/YaBB.pl Other CAD Tools >> Physical Verification, Extraction and Analysis >> Assura LVS avxp process https://designers-guide.org/forum/YaBB.pl?num=1147803001 Message started by ACWWong on May 16th, 2006, 11:10am |
Title: Assura LVS avxp process Post by ACWWong on May 16th, 2006, 11:10am Hi, I am using Assura 3.1 LVS and I seem to find that after the LVS has run, I always get two avxp processes which ramp up to maximum process usage, and need to be manually killed in order to free up the processor and allow me to continue to work. I was wondering whether anyone knows 1) what avxp does ? 2) why i get two invoked everytime I LVS, which don't die but ramp up the processor usage. 3) does anyone else suffer from this/have a solution ? if i manually kill these processes it doesn't effect the LVS run. I am running on LINUX. cheers aw |
Title: Re: Assura LVS avxp process Post by Andrew Beckett on Jul 24th, 2006, 2:04pm I'm pretty certain I've seen reports of this (I'm not on the Cadence network at the moment, so I can't check). Contact customer support via your normal support channel. Regards, Andrew. |
