Measurements >> RF Measurements >> ac source adding white noise?
https://designers-guide.org/forum/YaBB.pl?num=1149770097
Message started by cybq on Jun 8th, 2006, 5:34am
Title: ac source adding white noise?
Post by cybq on Jun 8th, 2006, 5:34am
hi all,
How to adding the white noise to the ac source in cadence to simulate the input SNR?
Thks in advance.
cybq
Title: Re: ac source adding white noise?
Post by Jess Chen on Jun 8th, 2006, 8:03am
That's what the "port" device is for. Replace your ideal source with a port device.
Post by mkaragou on Jun 8th, 2006, 8:15am
or connect a resistor with the input of a vcvs(voltage controled  voltage source) and place the output of the vcvs in series with your ac source
