Other CAD Tools >> Entry Tools >> compilation problem with behavioral elements ?
https://designers-guide.org/forum/YaBB.pl?num=1152748417
Message started by TT on Jul 12th, 2006, 4:53pm
Title: compilation problem with behavioral elements ?
Post by TT on Jul 12th, 2006, 4:53pm
Hi,
I have recently crashed my linux setup and reinstalled everything under Fedora Core 4.
Curiously I was able to resimulate most of the benches, but have now tis error
appearing:
/usr/lib/lib/libc.so:file format not recognized: treating as linker script
collect2: ld returned 1 exit status.
I suppose this is a compiler problem.
I have only reinstalled icfb.exe version 5.1.0
sub version 5.10.41.169 (32bits addresses)
Does it mean that I should not have used FC4 but rather any other linux platform ?
Thanks
TT
Title: Re: compilation problem with behavioral elements ?
Post by TT on Jul 13th, 2006, 5:19pm
Never mind, I reinstalled everything under RHE3 and everything works fine.
TT
