https://designers-guide.org/forum/YaBB.pl Other CAD Tools >> Entry Tools >> About symbol draw https://designers-guide.org/forum/YaBB.pl?num=1153913688 Message started by taos on Jul 26th, 2006, 4:34am |
Title: About symbol draw Post by taos on Jul 26th, 2006, 4:34am In the Cadence Symbol Editing, how to change the line from green to white? |
Title: Re: About symbol draw Post by bernd on Jul 26th, 2006, 6:17am The green lines in the Cadence Symbol Editor are drawn on the system layer purpose pair (lpp) 'device drawing', which is assigned to the display packet 'green' in the technology file. If you want to change the color of them you have to assign a other display packet to 'device drawing' lpp in your technology file. But this changes the color appearance of every shape drawn with the lpp 'device drawing' no mater if it is for symbols, schematics or layouts. No other way around this! Have a look at: http://sourcelink.cadence.com/docs/db/kdb/2004/Aug/11150798.html For what reason do you need white lines? Bernd |
Title: Re: About symbol draw Post by ACWWong on Jul 26th, 2006, 6:18am instead of Add->Shape you can use Add->Note->Shape (or shortcut n) to get white. what's wrong with green anyway ? its looks rather nice. |
Title: Re: About symbol draw Post by taos on Jul 28th, 2006, 4:33am Thank you! I only wnat to draw a A4 pattern to describe the schematic. |
Title: Re: About symbol draw Post by bernd on Jul 28th, 2006, 5:34am If you want to have a sheet surrounding you schematic, there are sample libraries in the Cadence DFII installation directory, have a look at <install_dir>/tools/dfII/samples/cdslib/sheets Bernd |
