Modeling >> Behavioral Models >> Behavioral modelling
https://designers-guide.org/forum/YaBB.pl?num=1155102826
Message started by chviswanadh on Aug 8th, 2006, 10:53pm
Title: Behavioral modelling
Post by chviswanadh on Aug 8th, 2006, 10:53pm
Hello every one,
I am new to behavioral modelling. I need some help regaring this.
What languages or tools can we use for behavioral modelling?
Are there any levels of modelling like the spice modelling?
What are the respective advantages and disadvantages of each language or tool?
Please help me with these
Thanks
Kasi
Title: Re: Behavioral modelling
Post by loose-electron on Aug 9th, 2006, 12:44pm
The common ones are:
Verilog-A
Verilog-AMS
VHDL-AMS
Google it, there is a bunch of stuff out there.
Jerry
Post by Ken Kundert on Aug 9th, 2006, 10:04pm
Verilog-A is available in SPICE-class simulators; pretty much all of them at this point. Verilog-AMS and VHDL-AMS both require full blown modern mixed-signal simulators like AMS Designer from Cadence or AdvanceMS from Mentor.
-Ken
Post by jbdavid on Aug 29th, 2006, 12:25pm
Actually the MOST common one is MATLAB.. but this suffers GREATLY from the lack of ability to compare the results easily with the transistor level design..
Verilog-A/Verilog-AMS models can be simulated in the same environment as the transistor level design, but it still takes a knowledgeable person to do all the right simulations.. and compare the right things..
jbd
