https://designers-guide.org/forum/YaBB.pl Design >> High-Power Design >> DC-DC converter or charge pump https://designers-guide.org/forum/YaBB.pl?num=1161106667 Message started by bharat on Oct 17th, 2006, 10:37am |
Title: DC-DC converter or charge pump Post by bharat on Oct 17th, 2006, 10:37am An input of 5V, 500mA is to be converted to 12V,2mA. Should I go for DC-DC converter or Charge pump. As per my understanding, for DC-DC converter the input has to be pulse. Should I think of changing the DC vltage to pulse to use the DC-DC converter OR charge pump should be better bet. Please suggest, Thanks |
Title: Re: DC-DC converter or charge pump Post by qadeer on Feb 8th, 2007, 11:46pm For dc-dc converter u have to use internal internal osc and ramp generator and o/p is controlled through duty cycle....dc-dc conv generally require external inductors and used if drive current is higher. For 2mA of drive, I think 3x regulated chargepump would be a better option. Here also u will be needing an internal osc for pumping the charge. Qadeer |
