https://designers-guide.org/forum/YaBB.pl Simulators >> AMS Simulators >> simulation AC in AMS environment https://designers-guide.org/forum/YaBB.pl?num=1162312637 Message started by Pavel on Oct 31st, 2006, 8:37am |
Title: simulation AC in AMS environment Post by Pavel on Oct 31st, 2006, 8:37am Hello I have a filter described in Verilog-A. How can I simulate it in AC. Should I - create symbol of this filter - do shematic with it and some source - call Analog Design Environment or there is more simple way to proceed? Thanks in advance. Pavel. |
Title: Re: simulation AC in AMS environment Post by ACWWong on Nov 1st, 2006, 7:02am what you suggest is what i would do to setup an ac simulation of your verilogA code. |
Title: Re: simulation AC in AMS environment Post by Geoffrey_Coram on Nov 2nd, 2006, 4:54am I'd just write a spectre netlist by hand and run spectre from the command line ... |
