https://designers-guide.org/forum/YaBB.pl Design >> High-Speed I/O Design >> the PWD vs. the TTL input level &nb https://designers-guide.org/forum/YaBB.pl?num=1162369713 Message started by dandelion on Nov 1st, 2006, 12:28am |
Title: the PWD vs. the TTL input level &nb Post by dandelion on Nov 1st, 2006, 12:28am Hi, My circuit accepts the TTL level input, I found the PWD(pulse width distortion) degrade seriously when the input TTL level varies,because the TTL level is defined as the low is less 0.8V and the high level is larger 2V. My circuit uses 0.6um CMOS process and works in 5V supply. The PWD degradation comes from the thereshold of the input can not track the different input TTL level, it becomes worse when the edge speed of input TTL is slower. Can anyone pls. tell me how to handle this issue? Thanks in advance |
Title: Re: the PWD vs. the TTL input level &nb Post by loose-electron on Nov 2nd, 2006, 8:10am Have you considered using a comparator for your input instead of a logic gate? That way you can define the switching point thru the use of a reference voltage. |
Title: Re: the PWD vs. the TTL input level &nb Post by ywguo on Nov 8th, 2006, 1:05am Hi, You have to make the edge sharp if you want to reduce the distortion or noise. Best regards, Yawei |
