Modeling >> Behavioral Models >> string parameter??
https://designers-guide.org/forum/YaBB.pl?num=1165351394
Message started by Aigneryu on Dec 5th, 2006, 12:43pm
Title: string parameter??
Post by Aigneryu on Dec 5th, 2006, 12:43pm
Dear all,
Can we pass a string parameter into an instance for a verilog-A macro?
I know there are real, integer,.. but I cannot find anything about the string.
Can somebody tell me if it is possible or not?
Title: Re: string parameter??
Post by Geoffrey_Coram on Dec 6th, 2006, 4:13am
I don't think you meant string parameter.  I believe your question should have been: is it legal to use a string literal as an actual argument for a macro?  And the answer is: yes.
For example, if you define this:
`define mydebug(x) $strobe("DEBUG: ", x)
then you should be able to call it with the string literal "line 101"
`mydebug("line 101")
If you really were asking about string parameters, they were added to Verilog-AMS LRM 2.2, and maybe that's why you can't find them where you are looking; they're not supported by all simulators yet.  I'm not exactly sure what your question is; are you trying to override an instance parameter?  Or trying to pass a string parameter as the argument to a macro?  Using the definition above, if you also have
parameter string myname = "X1";
`mydebug(myname)
-Geoffrey
Post by Aigneryu on Dec 6th, 2006, 6:26pm
Thanks Geoffrey,
 That's exactly the information I need.
