https://designers-guide.org/forum/YaBB.pl Simulators >> AMS Simulators >> ams designer starts and then hangs https://designers-guide.org/forum/YaBB.pl?num=1168481534 Message started by southofthebay on Jan 10th, 2007, 6:12pm |
Title: ams designer starts and then hangs Post by southofthebay on Jan 10th, 2007, 6:12pm Hi all, I am trying to run an AMS Designer simulation involving pure verilog rtl and verilogAMS converted from a PLL schematic. I have a weird problem: when I try to reset the charge pump inside of the PLL (either with a digital control pin or with a vpwl inside the schematic), the simulator hangs. I hold reset on at t=0 and then release it sometime later t>0. The simulation starts fine and runs until reset is released. It then runs for several hundred ns more. The simulation step size then decreases where it becomes 1 fs and then hangs. Do any of you have some suggestions as to what is causing the problems? Thanks, southofthebay |
Title: Re: ams designer starts and then hangs Post by jbdavid on Jan 22nd, 2007, 8:11pm first thing I'd consider is: Look to see if you have used a non-discrete variable as the argument to a "transition" statement.. Since it sounds like you are using schematic (analog) + digital and no Verilog-AMS models other than the connect modules, I'd double check those too... Are you using the right set? are they the latest version? Are you using a recent IUS release? (ie 5.7 or 5.8 or higher?) ALSO check the convergence settings. (after all THAT's whats getting bogged down. jbd |
