https://designers-guide.org/forum/YaBB.pl Design Languages >> VHDL-AMS >> 'RAMP attribute in Cadence https://designers-guide.org/forum/YaBB.pl?num=1172161781 Message started by wprodanov on Feb 22nd, 2007, 8:29am |
Title: 'RAMP attribute in Cadence Post by wprodanov on Feb 22nd, 2007, 8:29am Hello mates, I'm using ncsim simulator (Cadence IUS 5.7). When using 'RAMP attribute to define a voltage quantity from a voltage signal, sometimes the resulting quantity doesn't varies linearly as expected. Instead, it is "updated" abruptly only at the instant when the variation should finished. Anyone have seen the same behavior? Any idea how to work around? thanks william |
Title: Re: 'RAMP attribute in Cadence Post by abhi_kolpekwar on Feb 22nd, 2007, 1:32pm Hi, Are you setting a "break" on the signal that is used in the RAMP attribute? |
Title: Re: 'RAMP attribute in Cadence Post by wprodanov on Feb 23rd, 2007, 2:24am According to the language standards the use of break is not necessary when using 'RAMP, isn't it? Anyway, thanks for replying and I'll check the difference using or not using it. |
Title: Re: 'RAMP attribute in Cadence Post by alinalin19832007 on May 29th, 2008, 1:14pm Maybe the step time for the analog solver it is not constant |
