https://designers-guide.org/forum/YaBB.pl Modeling >> Semiconductor Devices >> Drain-Source asymmetry https://designers-guide.org/forum/YaBB.pl?num=1173032865 Message started by mg777 on Mar 4th, 2007, 10:27am |
Title: Drain-Source asymmetry Post by mg777 on Mar 4th, 2007, 10:27am I read somewhere that the drain and source of a submicron MOS transistor are not interchangeable because the wafer is angled during an implant. Can someone explain this? I forgot where I read this. I thought I saw it in Taur + Ning's 'Fundamentals of Modern VLSI Devices', which in my opinion continues to provide the best exposition of submicron device physics for an analog designer. M.G.Rajan |
Title: Re: Drain-Source asymmetry Post by vivkr on Mar 5th, 2007, 3:00am http://www.designers-guide.org/Forum/YaBB.pl?num=1165919635 Regards Vivek |
Title: Re: Drain-Source asymmetry Post by mg777 on Mar 5th, 2007, 3:11am Vivek, thanks for the link. The entire thread made interesting reading. Before posting I did try a search for "drain" on the forum's search box (top right), but it didn't return the thread you provided. I will send a note to the forum moderator. M.G.Rajan |
