Measurements >> Other Measurements >> mismatch analysis
https://designers-guide.org/forum/YaBB.pl?num=1178089042
Message started by Pravinkumar on May 1st, 2007, 11:57pm
Title: mismatch analysis
Post by Pravinkumar on May 1st, 2007, 11:57pm
Hi all,
Am trying to find mismatch in current mirrors through DC analysis. I try to measure the current output by varying the three parameters w, l and vtho of the key transistorsm in the current mirror. I am able to sweep the two component parametrs w and l. Since vtho is a model parameter am not able to introduce mismatch to it.
Is there any way to declare it as a variable so that i can use it as another sweep parameter? Is it like the pdk should support the variations of the vtho? any suggestions??????
Am using spectre simulator.
Thanks in advance.
PS: No model files available to run monte Carlo or dcmatch analysis.
Title: Re: mismatch analysis
Post by ACWWong on May 2nd, 2007, 8:04am
A simple (but crude) method would be to introduce a voltage source in the gate of the transistor to sweep the impact of vgs mismatch, which is correlated to threshold mismatch.
Post by John O Donovan on May 2nd, 2007, 9:34am
Hi,
If you are using BSIM4 or BSIM3v3 models, then there are instance parameters for doing this in Spectre. You can use
  delvto   shift in zer0-bias threshold voltage vth0.
 delk1    shift in body bias coefficient k1.
 delnfct  shift in subthreshold swing factor nfactor.
You can find descriptions in 'spectre -h'
Regards,
 John
Post by Andrew Beckett on May 8th, 2007, 1:41pm
There's also spectre's dcmatch analysis (see spectre -h dcmatch for more details). There are parameters in bsim4 and bsim3v3 (and some other models too), for example:
Code:
DC-mismatch dependent parameters:
816     mvtwl=0.0 V*m     Threshold mismatch area dependence.
817     mvtwl2=0.0 V*m^1.5
                         Threshold mismatch area square dependence.
818     mvt0=0.0 V        Threshold mismatch intercept.
819     mbewl=0.0 m       Beta mismatch area dependence.
820     mbe0=0.0          Beta mismatch intercept.
Regards,
Andrew.
