https://designers-guide.org/forum/YaBB.pl Modeling >> Passive Devices >> R and C per length values for 65nm technology. https://designers-guide.org/forum/YaBB.pl?num=1180199086 Message started by pkd on May 26th, 2007, 10:04am |
Title: R and C per length values for 65nm technology. Post by pkd on May 26th, 2007, 10:04am Hi ! I require the R and C values per unit length for the 65 nm technology and the references for that.At present I am using the predictive models and that's why I want to take into account the layout parasitics by adding some extra Rs and Cs in my schematics.Please help me in that. Thanks, Pratap. |
Title: Re: R and C per length values for 65nm technology. Post by didac on May 26th, 2007, 10:20am Hi, R per unit length can be found in your foundry documentation. C's depends on how its drawn the layout so its difficult to give you an estimation. One method I used is to drawn a couple of parallel tracks on the same metal and different combination of metals(5 and 4,6 and 5 and so on...) and do a parasitic extraction so I can get a magnitude order(I usually put them at minimum distance as a worst case). Good luck with your design. |
Title: Re: R and C per length values for 65nm technology. Post by pkd on May 26th, 2007, 11:03am As I told I don't have the foundry model.I only have predictive model.Hence I don't have any layout file also. :-[ Hence if I will have an estimate of Resistance per unit length and capacitance per unit length then I can have a guess of my total parasitics. Thanks, pratap |
