https://designers-guide.org/forum/YaBB.pl Measurements >> Other Measurements >> PLL transfer function https://designers-guide.org/forum/YaBB.pl?num=1181986704 Message started by sivacharan on Jun 16th, 2007, 2:38am |
Title: PLL transfer function Post by sivacharan on Jun 16th, 2007, 2:38am Hi Can anyone explain how we can plot PLL transfer function(Output phase/ Input phase) using spectre and spectreRF? If there are any documents pls share. Thanks, siva. |
Title: Re: PLL transfer function Post by Jess Chen on Jul 3rd, 2007, 8:48am The answer depends on how you plan to model the PLL. If you are using a phase domain model, you can generate and plot the transfer functions with Spectre. If you are using a voltage domain model, you may want to try SpectreRF of some other RF simulator. You could also try to simulate an impulse response and then take the Fourier transform to get the transfer function but that would be very tricky. How do you plan to model the PLL? |
