https://designers-guide.org/forum/YaBB.pl Measurements >> Phase Noise and Jitter Measurements >> Phase noise of divider resulting from supply https://designers-guide.org/forum/YaBB.pl?num=1199268128 Message started by scsiu on Jan 2nd, 2008, 2:02am |
Title: Phase noise of divider resulting from supply Post by scsiu on Jan 2nd, 2008, 2:02am Hi Ken, In the Design guide page 22, it mentioned that for the phase noise of divider resulting from supply, one need to compute the transfer function from signal source to the phase noise of each stage. What does it mean? Also, in my PLL, there is some buffer between each block, should I consider the effect of them? BR Marco |
