https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> differential source follower https://designers-guide.org/forum/YaBB.pl?num=1199324119 Message started by nxing on Jan 2nd, 2008, 5:35pm |
Title: differential source follower Post by nxing on Jan 2nd, 2008, 5:35pm Hi, Can anybody refer me a differential source followers circuit with common-mode feedback? I can not think one of them. Thanks Nxing |
Title: Re: differential source follower Post by nxing on Jan 3rd, 2008, 5:25pm So nobody pick up this topic? |
Title: Re: differential source follower Post by vivkr on Jan 4th, 2008, 5:50am Hi, I don't know of a differential source follower but perhaps you can get the job done by using a DDA (differential difference amplifier) in unity gain configuration. Search for differential difference amplifier in Google or IEEE Xplore. The authors of the original paper are Eduard Saeckinger and Walter Gugginbuehl (IEEE JSSC). Regards Vivek |
Title: Re: differential source follower Post by ACWWong on Jan 4th, 2008, 8:15am Hi nxing, when you say "differential source follower" do you mean two source followers which are differentially driven ? If so, the standard technique is to average the output signals by taking the centre-point of two resistors connected between the outputs, and using this in a feedback loop to control the common-mode levels into the source follower gates. This is covered in several textbooks, such as Razavi's "Design of Analog Integrated Cricuits" section 9.6. |
Title: Re: differential source follower Post by nxing on Jan 4th, 2008, 3:56pm Thanks for the replies! The usage of this block is actually btw and mixer and filter. actually, I don't even sure there is a really "differential" source follower exists since I can not find a "virtual ground point" like the common source differential pair. The output of mixer will directly connect to the gate of the source follower (DC coupled) so, even I can get the common-mode output voltage , I don't know where to feed it back? Any suggestions? Thanks |
Title: Re: differential source follower Post by thechopper on Jan 7th, 2008, 5:50pm Hi nxing, I might be misunderstanding your question but from your last description it looks you are trying to force the output common mode of your differential source follower by means of sensing it and somewhere feed the signal back. If that is the case I hardly see how that will work since there is no way to let the circuit work as a source follower and force the output common mode at the same time, if the CM signal is what you are interested in. If you only care about the differential signal you might end up using a differential pair. tosei |
