https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Accumulation mode capacitor https://designers-guide.org/forum/YaBB.pl?num=1200068615 Message started by Berti on Jan 11th, 2008, 8:23am |
Title: Accumulation mode capacitor Post by Berti on Jan 11th, 2008, 8:23am Hi all, I like to use a MOS transistor in accumulation-mode for decoupling of bias voltages. On the left-side of the attached figure, an accumulation-mode varactor is shown as provided by the design-kit I am using. My question is the following: Can I also use a MOS transistor as drawn on the right-side of the figure. Are there any problems? And what is the difference between the two structures (ESR etc.)? Thank you, Regards |
Title: Re: Accumulation mode capacitor Post by fran2k5 on Jan 12th, 2008, 7:33am Hi Berti, the only difference between the two structures is their C-V characteristics. While the PMOS-based one has an inversion region for which C=Cox, the other structure (on the left) does not have it. As far as the gate on the PMOS is higher than its source/drain voltage the accumulation cap is going to work. Regards, fran2k5 |
Title: Re: Accumulation mode capacitor Post by Berti on Jan 12th, 2008, 8:11am Thank you Frank. You confirm what I have expected. |
