https://designers-guide.org/forum/YaBB.pl Modeling >> Passive Devices >> Delay variation wrt frequency in a coaxial cable https://designers-guide.org/forum/YaBB.pl?num=1202162010 Message started by pkd on Feb 4th, 2008, 1:53pm |
Title: Delay variation wrt frequency in a coaxial cable Post by pkd on Feb 4th, 2008, 1:53pm Hello! I am doing some measurement in which I am using a standard coaxial cable as a passive delay element. My assumption is that the delay provided by the coaxial cable varies less than a pico second in thefrequency range of my operation...(47MHz to 47.5 MHz).... My doubt is that how far I am justified in my assumption...If I am wrong what is the approximate margin by which the delay of a standard coaxial cable will vary over a range of say 1 MHz? I have connected the coax cable to a chip with 50 ohms output impedance and the other end goes to a terminal which is terminated with 50 ohms.(In fact I have connected 5 coax cables by connectors to have a length of around 15 meters and delay of around 23ns for my application) Thanks in advance!!! :) |
