https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> save monte carlo mismatch params to file https://designers-guide.org/forum/YaBB.pl?num=1203667793 Message started by trond on Feb 22nd, 2008, 12:09am |
Title: save monte carlo mismatch params to file Post by trond on Feb 22nd, 2008, 12:09am Hello, i was wondering how i can save the mismatch parameters from a monte carlo simulation to a file. I read the solution number 11418896 "how to get param files for monte carlo mismatch variations" which essentially tells me to include the following into the netlist: savemismatchparams=yes mismatchparamfile="..." mismatchscalarfile="" However, when running spectre tells me that savemismatchparams is not a valid parameter for and instance of montecarlo. Any help is appreciated. Thanks. BTW, I am using icfb version 5.1.0 11/07/06 and spectre 6.1.0 10/10/06 |
Title: Re: save monte carlo mismatch params to file Post by Frank Wiedmann on Feb 22nd, 2008, 12:51am Well, the solution mentions MMSIM 6.2ISR, so I guess that you need a very recent version of Spectre. |
Title: Re: save monte carlo mismatch params to file Post by trond on Feb 22nd, 2008, 1:13am You are right, only saw 5.1.xx/6.xx and thought I was all right. Anyways, is there another way to save the mismatch params? ............................ ................. ......... ... After talking to my IT people I was told that we do have MMSIM 6.2. With this version it works like a charm. |
