https://designers-guide.org/forum/YaBB.pl Design >> High-Speed I/O Design >> max resistor of powerring? https://designers-guide.org/forum/YaBB.pl?num=1205834887 Message started by sissi on Mar 18th, 2008, 3:08am |
Title: max resistor of powerring? Post by sissi on Mar 18th, 2008, 3:08am what should be the worst resistance between any 2 points exceed from the esd discharge paths? thx |
Title: Re: max resistor of powerring? Post by loose-electron on Mar 19th, 2008, 10:50am You are trying to keep a low IR drop when an ESD event occurs, because that voltage will appear somewhere in your circuit as part of the ESD budget. That said, ESD events can have very high currents, over 1 amp. Also, you are trying to keep a low R due to current surges and voltage stability on both power and ground. You need to model the above two, and quantify the current loads, for both power and ESD, then you can quantify the resistance number that you need to stay underneath. Generally, well under 1 ohm is where you would like to be, but a specific number is going to be based upon the above considerations. Hope that helps, Jerry |
Title: Re: max resistor of powerring? Post by sissi on Mar 19th, 2008, 7:09pm Thank u very much for reply. but how to model the esd discharge? as i know, it is pointless that simulating the esd discharge. could you give me a model or some advice? i am a newbie. sissi |
Title: Re: max resistor of powerring? Post by thechopper on Mar 19th, 2008, 8:06pm The ESD models are standarized. The most common ones are human body model (HBM), machine model (MM) and charged device model (CDM). HBM is represented by about hunderd picofarads and 1.5K resistor in series, while MM has much less series resistance (do not recall exact numbres now). Hope this helps Tosei |
Title: Re: max resistor of powerring? Post by sissi on Mar 19th, 2008, 11:00pm hi,Tosei you mistook me :) |
Title: Re: max resistor of powerring? Post by loose-electron on Mar 20th, 2008, 10:32pm agreed - the JEDEC standards define the HBM, MM et. al. models, which you do with ideal components and and ideal switch. THis will give you a quatitatized approach to the currents caused by an ESD event. caution with the error tolerances in the simulator, 2KV at one place in the simulator and <1V elsewhere can mess things up jerry |
