https://designers-guide.org/forum/YaBB.pl Simulators >> Timing Simulators >> FineSim https://designers-guide.org/forum/YaBB.pl?num=1206959332 Message started by Visjnoe on Mar 31st, 2008, 3:28am |
Title: FineSim Post by Visjnoe on Mar 31st, 2008, 3:28am Dear all, does anyone have experience using FineSim (Magma DA) as FastSPICE simulator? Is it accurate for analog/mixed-signal? How would you compare it to HSIM/Nanosim/Ultrasim/...? Kind Regards Peter |
Title: Re: FineSim Post by dt_banme on Apr 17th, 2008, 10:16pm FineSim Spice is a spice simulator, it works very well for top level simulation on small to average analog/mixed-signal circuits, ~ 200K-300K devices, especially if the mixed signal design has very high content of analog. I haven't try on designs with higher transistor count yet. The accuracy is at full spice accuracy level. If you are running with parallel processing using 4-8 core system, it will be a few times faster than a typical fast spice simulator. It's fully compatible with Hspice and doesn't require much setup. The default works fine for most analog circuits. In general Hsim/NanoSim/UltraSim are more suitable for large mixed-signal designs with high digital content, post layout verification and memory. I hope this will help. |
