https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> How to generate IBIS model using spectre simulator https://designers-guide.org/forum/YaBB.pl?num=1207275334 Message started by holddreams on Apr 3rd, 2008, 7:15pm |
Title: How to generate IBIS model using spectre simulator Post by holddreams on Apr 3rd, 2008, 7:15pm Any one has generated IBIS model using Spectre simulator? Can you give me some suggestions? Best Regards, |
Title: Re: How to generate IBIS model using spectre simul Post by icsoul on May 29th, 2008, 6:39am holddreams wrote on Apr 3rd, 2008, 7:15pm:
I think the IBIS model is just like a look up table. The simulation result from your simulation with spectre will be changed to IBIS format. There is a small tool from intel can do the format conversion. I forget the tool's name. You could search it. Good luck!~ -icsoul |
