https://designers-guide.org/forum/YaBB.pl Measurements >> RF Measurements >> Balun https://designers-guide.org/forum/YaBB.pl?num=1213173490 Message started by ali.m on Jun 11th, 2008, 1:38am |
Title: Balun Post by ali.m on Jun 11th, 2008, 1:38am Hi: I am wondering if any one knows 24GHz Balun (Part Number) for Measurement? Regards Ali |
Title: Re: Balun Post by pancho_hideboo on Jun 11th, 2008, 7:51pm ali.m wrote on Jun 11th, 2008, 1:38am:
What value for low frequency do you need ? |
Title: Re: Balun Post by ali.m on Jun 11th, 2008, 8:36pm Hi Pancho: The lower the better but few MHz would do too. Ali |
Title: Re: Balun Post by pancho_hideboo on Jun 12th, 2008, 12:02am The followings might be useful although they are not completely matched to your needs. http://www.krytar.com/html/180deg.htm http://www.picosecond.com/product/category.asp?pd_id=11 |
Title: Re: Balun Post by ali.m on Jun 12th, 2008, 12:37am Hi Pancho: Thanks for your quick answer. |
