https://designers-guide.org/forum/YaBB.pl Design >> High-Power Design >> Battery energe and voltage https://designers-guide.org/forum/YaBB.pl?num=1213585137 Message started by ywguo on Jun 15th, 2008, 7:58pm |
Title: Battery energe and voltage Post by ywguo on Jun 15th, 2008, 7:58pm Hi Guys, We integrate more and more LDOs into a SOC. At the same time, the LDOs need to work powered off a Lithium-ion battery. I am looking for some literature about the characteristic of Lithium-ion battery, like its life, the relationship between the energy and voltage, and so on. Any comments and recommendations are appreciated. Yawei |
Title: Re: Battery energe and voltage Post by Berti on Jun 15th, 2008, 10:35pm I had the same problem recently. But I couldn't find good literature (without reading books of 1000 pages). What I have been told is (for Lithium-ion battery). Nom. Voltage: 3.6V Lowest voltage: 3V Voltage peaks during charging: up to 5.2V Any comments are welcome! Cheers |
Title: Re: Battery energe and voltage Post by analogue_guy on Aug 9th, 2008, 12:57pm Berti wrote on Jun 15th, 2008, 10:35pm:
Hi Where did you find this maximum voltage for charging (5.2 V) ? Also, the charge current should be considered and as far as I know the minimum voltage during charging. http://www.batteryuniversity.com/print-partone-12.htm http://en.wikipedia.org/wiki/Lithium_ion_battery br |
Title: Re: Battery energe and voltage Post by sheldon on Aug 9th, 2008, 7:50pm YW, You might also want to look at "Dynamic Lithium-Ion Battery Model for System Simulation", L. Gao, et al, IEEE TRANSACTIONS ON COMPONENTS AND PACKAGING TECHNOLOGIES, VOL. 25, NO. 3, SEPTEMBER 2002 "Accurate Electrical Battery Model Capable of Predicting Runtime and I–V Performance", Min Chen, et al., IEEE TRANSACTIONS ON ENERGY CONVERSION, VOL. 21, NO. 2, JUNE 2006 The model should also include thermal dependence and the degradation in characteristics as a function the number of charge cycles. Best Regards, Sheldon |
Title: Re: Battery energe and voltage Post by sheldon on Aug 15th, 2008, 1:58am FYI, There was one other paper that might be useful for reference so I am including it in this discussion. EDN: Oct 28, 1993, pp 117-132, by Steven Hageman "Simple PSpice models let you simulate common battery types" This paper covers most of the other types of batteries you might want to model. Best Regards, Sheldon |
